Does anybody know if the Tie Rod Pin and Bush Assembly (133101) from SNG fits in the Tie Rod End RH (C29094*)?
I’m asking this because mine Tied Rod End RH (same as C29094*) needs new rubber (due to disintegrate).
At first side it seems impossible to replace the Tie Rod Pin.
When I got my car the pin and bush combinations on both sides were flogged out with the pin lifting vertically a significant distance on turning the wheel. I replaced mine with new units that included poly in place of rubber - much better. FWIW. Paul
