Is there a list to hand ?
Need to know disc to hub bolt torque !
Just checked my ‘S’ manual and there are no torque settings for that item, 2 grunts should be ok, its held on by the wheel byway.
Oops, fair call still two grunts
I’m a hard biker my two grunts maybe 1 too many
Had a look in a XJ6 Haynes Manual , far better then there MK2 Manual
Torque settings listed in every section .
Would think the bolt would be about the same Torque !
I believe there may be tables with an engineering standard for different diameter, thread, rating etc.
So long as the fasteners are the same size as the XJ, I reckon you would be good
Just checked Tony , bolts are the same part no 201390 .
Then two grunts and one expletive…
Ahh I forgot about the expletive, that when the socket slips off the bolt
…no neck cords, just the two grunts?
perhaps that, if never seen copper slip.
Put the hubs on my 62 Mark 2 about 8 months ago, looked everywhere for torque setting. I used a generic setting, I read. Go with 2 grunts, I went with sore back, no work on car for 2 weeks.
Snowball
