I have Aquired a rear Suspension assembly with the 3.54 Differential ratio and after all kinds of little stuff I hit a big snag. The Bushes are in need of replacement and I don’t know how to get the trailing arm off of the control arm. Does anyone have any advice?
Remove nut on lower spring/ damper pivot bolt and drive it back until flush with lower arm, collect small spacer and swing damper inwards. Release locking tab on special bolt at trailing arm small bush end and remove special bolt. Cut away on head of bolt needs to be turned to clear lower damper mount boss.
