My 94 XJ40 's transmission has gone into limp mode. Took it to the best shop available and they are having no luck. Have checked the firewall relay and fluid levels, no luck. The shop keeps focusing on failure codes for my ZF4HP24. But they don’t have a compatible reader. When I do a search at say Ebay I am over whelmed by volume. Can anyone with experience recommend brand & model that will serve my requirements. Thanks, John Meade
Jon,
I doubt very much that the problem is in the transmission itself. Over the years there have been many reports of the car going in to ‘limp home mode’ and I do not recall any being due to a faulty transmission unit.To get a flavour of the sort of problems encountered enter ‘Limp Mode XJ40’ in the archive search engine facility. There are pages of posts on the subject - this being typical -
A favourite suspect after the firewall relays seems to be an oil soaked TPS.
I believe Bob Gauf’s post answers your question about a code reader for these cars.
Jon, years ago I opened up the transmission control module (TCM) and found a cracked solder joint where a relay ( yes, there’s a relay in there) is soldered to the pcb. My car ('94 MY) also went into limp home mode intermittently so it can be one of the cause. Worth checking it.
