Dumb question, can I just update modulator, vacuum hose, change filter and add a shift kit without a total rebuild.
I’m also looking at new gasket and maybe better pan. I hear the gasket is a different shape.
Sorry to hijack thread.
New vacuum modulator not too hard. A bit fiddly working around exhaust pipe.
New vacuum hose, a bit fiddly trying to feed down from above.
Remove pan, gotta deal with that bloody mount. I would buy a new pan with drain plug. I did NOT get extra deep, as it may bottom out on our cars. Same shape gasket (don’t get cork, i got FelPro). I still had to do some re-torquing to stop a leak. Molded steel pans onto aluminum transmission cases, always trouble.
With pan off, it’s not too crazy doing shift kit. Just be very careful with where the little balls go. Take photos, draw diagrams.
Thanks Greg, I am in no way a transmission expert, but I am interested in tighter shifting if I can work it in to the transmission service.
I think I’ve all bit given up on the idea of a manual shift.1
