Hello all, I’m New to the forum. I’ve been searching for a lil while and found plenty of limp home modes on the xj40s but not on the x300s. I have a 97xj6l 4.0 with 88,000 that I traded my 97 lincoln mark viii for.
when I picked it up the guy that had it before me said that sometimes the car will go into limp home mode but with a quick DTC code erase on the TCM the car would operate as designed and shift properly. Now I can no longer do that and the vehicle is stuck permanently in limp home mode. Where do I start as I am not familiar with the electrical of these beasts. I just want to drive it lol.
The DTC that I can pull is for the torque converter clutch solenoid. If I remember correctly the code is P0702. I was talking to my shop foreman about it and he had mentioned that there might be a solenoid kit with a wiring harness that takes care of the lucas solenoids and wiring has anyone here found a fix that did not require a replacement transmission ?
