I always get a bit confused with designation of the XJ series through the early 2000s.
So I will spell it out.
2003 year, VIN 34RG00689
According to my X350 pdf manual it has a ZF 6HP26 6 speed box.
The car has 145,000kM on the clock and generally gives little trouble.
I spend more time on my two XJ-Ss.
I have a hoist in my garage and a lot of tools.
Recently the XJ made a couple of harsh gear changes under moderate acceleration and flagged a transmission fault on the instrument cluster.
I know it is claimed that the oil is good for life, and maybe it is and maybe there are fairys at the bottom of the garden too.
I would feel happier to change the oil. Doing a forum search on the topic did not get me the full story.
This is a car in Australia so that might colour some of the replies to my questions:
Do you really need the special tool 307-452 to get the filler plug out ?
The pdf manual says use Shell M1375.4. Is there an alternative ?
Is it easy to get the pan off and change filters ?
If so any suggestions where to get the parts apart from regular Jag dealers ?.
Just a comment on that pdf file. It is such a long winded document and not easy to zero in on the information needed to do anything. Seems to spend more effort telling you not to do stupid things like taking a road wheel off before jacking the car up first. Is it really aimed at morons ?
As it turned out one of the ballroom dance group we meet up with has a transmission shop. Too far away to take the car over there for a change, but he will get me the full kit of all items needed including the connector sleeve. He knows which suppliers have the best aftermarket sump covers etc.
Anyway, may thanks for the feedback.
Over the coming Xmas holiday will also tackle the rear pass door lock that does not ever lock. I can see some of the rubber gaiters over various suspension components are looking ragged, more for the “to do” list.
