My spouse and I used the contraption in the first two photos during the initial bonnet reassembly and fitting phase. Started with the bare shell (in this photo) and used it throughout final reassembly (flanges and ducts). Think we had it on and off four times before the fit was finalized and it was deemed ready for paint. Then it went on the rolling trolley for final paint and stayed there for bumpers, lights, grill, etc. When the rest of the car was ready, I picked up the front portion with the motorcycle jack (padded with pillows) and three of us rolled it back over the chassisâŚone person at each rear corner and one pushing the jack. Dropped right into place on the chassis pinsâŚabout 15 minutes for three geezers. Gaps were all fine, Had to pull two shims on the hinges to get the fit where I wanted it. (I spent weeks getting the bumpers to fit and wasnât about to risk knocking them it out of alignment by sliding it around on itâs nose).
Eric,
Your pick up points for your spreader bar, are they thin strips of metal between the fender and center section, dead ended on the underside?
Thanks,
Ken
Ken,
Theyâre lengths of that perforated metal plumbers strap (two per side for safety). The lower end is secured by one of the flange bolts that join the fender/wing to center section (left out the spacer for that boltâŚreplaced it after last lift). Later in the process I put masking tape on either side of the straps in case of marring or chips in the final primer, but it was never an issue.
Just to shorten this, the trial fitting process is to :
( AFTER the bonnet is in epoxy primer )
Bolt wings, center section, and under panel together , then
Mount hinges in approximate position and place bonnet on car followed by
a. Get the shims correct
b. Get the left-right spacing correct on the pivots
then snug hinges, remove bonnet, glue in all flanges?
This bothers me because I want to bond in flanges, THEN epoxy prime. The exact opposite of this technique. Any other input? What am I missing?
When I fit the bare bonnet shell I had to do the âcargo strap squeezeâ at the aft end in order to get exact alignment with the sills. Also had to lengthen the slots in the adjustment brackets at the upper rear corners to keep the proper shape. While minor, these adjustments could have impacted ideal fit of the duct work (and put stress on the shell) if the flanges had already been positioned and glued. (I positioned and glued the ducts/flanges with the previously adjusted shell off the car).
Timing of the primer can be handled any number of ways. If your concern is bonding to epoxy, I donât believe itâs an issue. I epoxy primed the shell before assembling and fitting, then sanded and scuffed the bonding surfaces after establishing their exact location in the âadjustedâ shellâŚcould have sanded back to bare metal, but to what purpose?
Ok,
was this bonnet original to your car?
Isnât there enough play/slop to allow the parts bolted to the flanges to wiggle enough to fit?
Yes it was, but it had been off the car and shoved around for 30 years on itâs tail end. And when it was disassembled into sections, it inevitably lost the precise original settings in spite of my having placed a few telltale markings with a file. Thereâs not much slop and the odds of imparting distortion is pretty high in my opinion. The ducts donât simply float in the structure, they provide torsional rigidity.
69 Coupe -Currently being re-assembled
Good Day. This couldnât be more pertinent to my current progress. I have just 2k Epoxyâd the inner bonnet to my 69â and am preparing to epoxy the other components that have all been blasted, recently. (I did not blast the center section or wings, but I did sand all the way to metal) The bonnet is original to my coupe and has been off the car for 28 years, standing on itâs end.
Prior to epoxyâing the inner bonnet, I re-installed all components and measured the sides of the wings at the firewall corners and just to the rear of the wheel-wells. Those measurements were very close to measurements from my newly installed sills at the same positions. The adjustment flanges at the base of the wings/center section will allow for approximately 1/2" movement either inward or outward when I mount onto the frame.
It is my intent to epoxy prime all components, then base/clear all, then install everything LOOSELY and then mount on the car vertically. Then I will slowly lower and check everything for clearance etc. Once I am happy with the fit/clearances, I will tighten bolts from beneath to maintain the fit. Then remove the bonnet and tighten everything. ( engine is not in the vehicle ). Some of my procedures are altered from those of others on the forum because I do everything by myself, with very few exceptions. When absolutely necessary, my wife assists. Over the years I have become adept at building jigs to serve as helpers!
I should mention that all the flanges are newly Sika-Flexâd prior to epoxy.
I had to make a cradle to hold the bonnet of my car this week for transportation to the paint shop.
Among other things I used the hardened carrier/pivot locations for the front. All was made of wood and it occurred to me that given most of us are probably handy with wood, why not just make up spacers/shims in wood to get the bonnet location very close them measure everything and then make or purchase suitable shims in metal?
Sounds like a good idea to me anyway and I will try it once o get the entire car back!
I found the factory shims very easy to work with. having the car raised enough to allow the bonnet to be standing plumb on the hinge pins(bolts) the fore and aft shims that are open ended can be tapped in after loosening the bolts. they can be pulled out by the hole on the end. the vertical shims just drop in as needed . shimming was done without removing the bonnet. I hold the bonnet in place with a stiff leg and an adjustable strap. my car came with extra parts that included shims. I am waiting for some additional new open ended shims for the final fine tuning.
Reviving old thread.
We previously removed the 2 pivot bolts to garner better access for engine work.
This evening we replaced those bolts but now have an alignment issue with the bonnet.
Any advice for correcting this and getting the alignment corrected?
It wasnât the pivot bolts: what you put in were the spring link bolts. They have little effect on the fit.
Getting a good fit can be a real PITA⌠best we talk.
A good psychiatrist is a needed when dealing with traumatic bonnet disorder.
