If your carbs are not perfectly balanced for air flow then one cylinder may be getting a bit of a richer mixture from one carb and that would make it run richer than the other cylinder
ONE carb–feeds air /fuel mix to two cylinders–so same and only one carb:
agree with Les look for an air leak between carb and cylinder-or an obstruction in the intake path, -but are you sure it is fuel rich–or is it oil getting by rings on one.
Nick
It’s not as simple as you think. There’s a balance passage that links the carbs. So the flow can cross the obvious boundaries. What’s going on with the other plugs?
I had time today to compression test all 6 cylinders. The engine is a replacement from an xj6 and is 8:1 compression. All 6 cylinders tested between 138 and 142.
I haven’t checked for vacuum leaks, but will do so as soon as I can.
Also, is it possible a problem with the distributor, Lucas 22D, could cause a difference between plugs on the same carburetor? Difference in strength of spark? The 3 carbs are SU HD8.
There are a million and one reasons why they can be different. For example, if the two inlet runner lengths are different, then the air pressure in the longer runner must be lower and the airspeed will be higher, all other things being equal. Those two columns of air don’t move at constant speeds - the inlet valve opens, the air column starts moving in, it then gets chopped when the inlet valve shuts. Cylinder filling and exhaust emptying isn’t a constant across all cylinders at all revs.
Next factor with carburettors is that atomised fuel is always condensing onto the inlet runner surfaces and always evaporating off of them. This isn’t a constant either as it’ll vary with rpm and with temperature.
We haven’t even got to the cylinders yet or considered whether spark plugs are identically performing…
Update!
Removed carb which was feeding the two pistons in question(one lean, one rich). Re-centered needle, cleaned and looked for anything off and reinstalled.
Redid tune as outlined in manual. Looked for vacuum leaks by spraying carb starter around likely areas.
Still getting piston one lean, and piston two rich. I used a Gunson Colortune and it did show piston one running lean, and piston two running rich. With those pistons being fed by on carburetor, I don’t see how it is possible!! I guess if there were a vacuum leak around the manifold where the number one piston is showing lean, that could explain it. But I’m not finding a leak. I also, took the car for a long run previously.
As Marek says, there are a million reasons why this could occur! I’m not sure I’ll ever find the answer.
The other plugs are all fine with the expected color, light tan.
I did a compression test and all cylinders tested between 138 and 142. The engine is a replacement from an XJ6 and is an 8:1 compression. I haven’t done a leak down test.
