During my restoration I have added another temp sensor in B bank where EFI sensor used to be. And mooved the EFI sensor to A bank where air pump vacuum thermo-switch used to be.
Since I now had 2 temp sensors, the idea of using them both for temperature gauge never left my mind… I just had to figure out the way how to do it…
Another idea I had on my mind was to somehow modify this stubid temperature gauge so that its readings would make more sense to “untrained” jaguar user
After analysing temperure sensor resistance and how the gauge reacts to resistange change a very simple idea came into my mind that could address both of these issues… An idea too simple to be true so I had to do some bench testing…
I have wired up both temp sensors in parallel and here’s what happened:
Engine temp ~85c (185f)
Engine temp ~90c (195f) 82c thermostats should be fully open by now
Engine temp ~96c (205f) 88c thermostats should be fully open by now
Engine temp ~110c (230f)
Engine temp ~120c (248f)
With this arrangement I am getting an average reading of both sensors and I think temperature gauge readings will make much more sence now
