A rat chewed up some wires in my 1995 XJ6. Nothing significant but this wiring harness seems like it might be important. Anyone know what this is?
thanks,
Thomas
thanks,
Thomas
G’day Thomas,
It looks like the cable from your front wheel ABS sensor. If you have a look at the same location on the other side of the car you should see another similar cable which should give you an idea of where the chewed one should connect to.
Cheers,
Jeff.
Thanks or the info. I checked the other side and did see a similar cable.
