Installing the new joints. I think I have most parts figured out as to where they go, (but would appreciate a double check) but there is one that doesn’t obviously fit anywhere. Anyone have knowledge?
Looks like a thread protector for packing and transport.
Not sure if you intended your title to read that way; your picture is of the standard replacement upper front ball joint, not an aftermarket sealed lower unit.
That plastic piece? I’ve never seen one before. Is it supposed to act as a spacer to keep the gaiter extended? Also no sure what that smaller o-ring is supposed to accomplish? The kits I installed years ago didn’t have these parts.
It does fit over the threads, but not over the tapered shaft that goes through the gaiter. I suppose I could stretch it over the taper, but then it would just foul on the slot in the a-arm, so I really don’t see it there.
The small o-ring fits over the gaiter and appears intended to hold the gaiter on to the plastic retainer on the a-arm.
It goes between thw Gaiter and the Wishbone to ensure that the Gaiter seals in the ball pin and stop excess grease escaping from the Gaiter. It’s exactly as an OE supplied kit. It’s installed tophat up.
Actually, looking at an enlarged picture, I’m pretty sure that “O” ring replaces the Circlip that was originally used. You have to put in boiling water to allow it to be stretched over the gaiter to hold it on the plastic retaining ring.
I have used these before, personally the circlip is a better idea as i’ve had the O rings break if they were old stock and brittle.
So if that holds the gaiter what would the large ring do? I agree on the clips. They seem stronger although eventually they do nip the gaiter, but by that time the gaiter is ready for replacement anyway.
Huh, I always assumed the gaiter fits into the groove in the arm and the clip just holds it there. So the rubber ring goes into the groove and then the gaiter goes over that, and then the other ring goes on top of both? This sounds way more complicated than the way mine are installed.
Just to be clear, there are two rubber rings. The large one is sized to fit over the gaiter and hold it on the pastic ring that fits on the wishbone end. The small one is about the size of the hole in the wishbone, where the race and the srping go. The only place I can see that this might go is around the race and inside the wishbone. I fitted it on the race then inserted the race and it looks like this. I don’t really see any value in this at all, but I can’t see any other place that it fits.
