hi everyone
i have an ac cobra fitted with a v12 xjs and a 4 speed gearbox.
problem is the gearbox took it for a spin last weekend and first
gear is making a rattling noise only happens in first gear.
i was told it is an e-type 4 speed has anybody got any ideas bout
what this could be.
many thanks
colin–
cobra89
liverpool, United Kingdom
Hi Colin,
I have no idea but wow! a Cobra with a 12! Any chance of a few
engine bay pics?
Les Marston,
Alberta Canada,
'87 xj-s
'79 Harley-Davidson------------------------
“Cats & Hogs”
On Sep 23, 2005, at 1:17 PM, cobra89 wrote:
hi everyone
In reply to a message from Les Marston sent Fri 23 Sep 2005:
hi all very sorryy but just come in from pub. I’ve had no replies at
all about gearbox does that mean nobody knows about a 4 speed
gearboxn or4 am I jut out of orderasking questions.ps I am ner–
cobra89
cobra89
In reply to a message from cobra89 sent Fri 23 Sep 2005:
cobra89, pull the gear box check the cluster gear could be a
missing tooth. awa 99xk-8 conv. 93 xjr-s coupe 69 corvette conv 83
mustang conv 5.0–
I have an ac cobra fitted with a v12 xjs and a 4 speed gearbox.
In reply to a message from awa sent Mon 26 Sep 2005:
Hi Colin
I also have a dax cobra fitted with a V12 but on advice I have
opted for the BMW Getrag 5 speed box rather than the Jag 4 speed. I
am reliably told it is a much stronger box although there is a lot
of fuss in making up the conversion plates etc. AJ6 engineering
have a good web site and are very helpful if you get really stuck,
they are up your way (Cheshire). They also dotheir own gearbox
conversions etc.
Out of interest are you still running an E type engine on carbs or
is it a later injection lump?
Still having problems tuning mine right, be on the road next spring
with a bit of luck.
Regards
Neil–
In reply to a message from Cam Cover sent Mon 26 Sep 2005:
thanks for the info
the original engine was a v12 run on carbs but dont know if its an
e-type engine how would I find that out.
i still have the old engine but crank has gone.
i took an engine out of an 87 xjs and put my carbs onto it instead
of efi unfortunately the head gasket has gone so I have bought an
engine out of an 1978 xjs he is swapping the engine for a diesel
rover dont know why.
i am keeping the efi on this engine im swapping engines on sat so
will hopefully find the problem with gearbox also
cheers
colin–
cobra89
