My car has now reached 60K, so I wanted to replace the transmission
filter, unfortunately I could not remove/lower the transmission
fluid pan! The two exhaust pipes are simply too close to the pan.
It appears that the only way to do this would be to remove the
exhaust! This of course would mean lots of hours under the car
trying to dismantle the rusty exhaust. I’m I missing some thing
here? your help would be highly appreciated.
Danny,
95 Jaguar XJ 12
87 Porsche 928S4–
Danny K
In reply to a message from Danny K sent Tue 6 Sep 2005:
hi when my transmission on my 1996 xj12 was replaced, they had to
take off both exhauasts to get to the pan, this mite be the only
way???–
Vaughnt
exhaust!
My 1994 car had to have its exhaust removed to access the trans also.
A word of advice on this though, if your 95 has the same trans, which I
suspect it does, its a fairly standard GM truck transmission, and I just
took it down to the local shop. They dropped the trans , replaced all the
seals, filters and o rings etc, sealed it back up and reassembled
everything, basically a complete trans service for a measly $600. Certainly
worth every penny of not having to deal with rusted exhaust components and
waiting for liquid wrench to set etc.
Before my trans would leak regularly , sometimes several large puddles,
since the trans has been dry and behaved perfectly.
Its one area you can use a general shop, and not a Jag specialist.
Daniel
1994 XJ12
1995 XJS 4.0
Visit the Jag Lovers homepage at http://www.jag-lovers.org for exciting services and resources including Photo Albums, Event Diary / Calendar, On Line Books and more !----- Original Message -----
If you have a ‘‘sawsall’’ you can cut the pipe in the area needed and
then acquire a couple of ‘‘Band’’ clamps to re-attach them.
This type of clamp allows you to butt the two pieces of pipe
together then secure them with the band clamp for a leak-free and
secure repair. No welding is required either.
You can find ‘‘Band’’ type clamps at most auto parts stores or order
them through Summit Racing or Borla.
Doug Franklin, Owner
Performance Jags of Indiana
www.performancejags.com–
Sporty01 - Indy, USA - '89 XJ-S V12 & '85 XJ6 Ser III
Indianapolis, IN, United States
