Ok, heres a curly question for you other Jag owners here in Australia.
I need to hire a Borescope.
For those who dont know its a device you can put though holes to inspect
engine internals.
I have seen them in the past, but need to get hold of one now.
The problem that has arisen is this, I bought a second hand engine for my
XJS from a reputable company here in Aus.
Got it into the workshop where I work, did compression tests etc, then
fitted it into the car.
Now, when I go to line the timing up to fit the distributor, the engine
will not turn past a certian point. If I take it backwards, it will nearly
reach that same point, but not quite.
This point is as no 3 and 4 cyls on the LH side are approaching TDC. I probe
around with a small magent on a stick, and am "rewarded " with a small self
tapping screw in side No 3 cyl. Its bright and shiny, undamaged. But it
still will not turn over.
My guess is, some clown at work has decided to sabotage me.
So… to save me taking both heads off, I would like to get hold of a
borescope to examine each cylinder, to see if there are any more little
surprises inside them.
Anyone local , especially the Sydney area, know where I can get hold of one?
Dont suppose we have any proctologists amongst us?
Andrew Holley
Sydney Australia
