Hi All,
My car has a Thermal Valve EAC 2630 mounted on the left hand water pipe that
nothing is hooked up to. It has two vacuum line attachments. I assume that
it was used prior to the recall associated vapour recovery. If this correct
and it is not needed, could it be replaced with a temperature gauge so that
actual water temps could be read.
Byrnal Haley
89 XJ-S Conv.
Beaufort, SC
-To unsubscribe go to
Hello Byrnal!
I believe that the thermal valve you describe is supposed to be used in
conjunction with the drivers side (left) fuel pressure
regulator near the front of the engine on the end of the fuel rail. The hose
barb that comes straight out from the fitting goes to
a port on the front of the left manifold, the angled barb goes to the left
regulator on the fuel rail. I wonder how that is plumbed now?
Purpose is to allow greater fuel pressure when hot to prevent vapor lock.
kind regards,
Don Buresh, 1991 XJ-S V12 Coupe, Classic----- Original Message -----
To: “V-12” v12-engine@jag-lovers.org
Sent: Saturday, April 14, 2001 1:43 PM
Subject: [v12-engine] EAC 2630 Thermal Valve
Hi All,
that
correct
that
Byrnal Haley
89 XJ-S Conv.
Beaufort, SC
Jag-lovers Forums - Jag-lovers
Donald, The thermal valve you are talking about is on the left side fuel
rail on mine. The valve I am talking about is on the left side water pipe.
The vacuum line to the valve came off of the manifold crossover pipe and
then from the valve to a delay valve and then to the cannister, I think.
Byrnal----- Original Message -----
To: Byrnal Haley <@Byrnal_Haley>; V-12 v12-engine@jag-lovers.org
Sent: Saturday, April 14, 2001 6:50 PM
Subject: Re: [v12-engine] EAC 2630 Thermal Valve
Hello Byrnal!
hose
kind regards,
Hi All,
that
that
correct
that
Byrnal Haley
89 XJ-S Conv.
Beaufort, SC
