Ljo wrote:
I am in the process of restoring my 1973 series 2 double six
which I intend on keeping and using for road trips not
racing.
Carbs?
Is there a consensus on EFI conversion for a pre HE engine?
You’re talking about converting from carbs to D Jetronic, the EFI
that came on the Double Six only a couple of years later? Or are you
speaking of converting to a modern EFI system such as megasquirt?
From a purist point is it worth doing or will it devalue
the
car.
You’ll probably find general agreement here that these cars are so
devalued already that it scarcely matters. The money you save in
fuel economy and maintenance alone over a couple of years is probably
more than the entire value of the car! Most Jaguar XJ owners have
already resigned themselves to being the last owner of the car, do
with it whatever makes you happy, drive it until the wheels fall off,
then have it towed to the junkyard.
From a practical point is it less hassles balancing the
carbs, better running engine, improved economy/power or is
there more?
The four carbs on the pre-EFI V12 are the very definition of hassles.
Going with EFI of any sort will leave you wondering what to do with
your weekends. However, I’d highly suggest you also consider an
ignition upgrade, at least to Crane Cams or Lucas CEI and possibly
all the way to Megasquirt or something similar. This might affect
your decision on what to do about the EFI, since going to D Jetronic
would require distributor work to install the trigger board while the
later EFI options do not.
What is involved apart from rails, manifold, fuel pump and
computer.
You probably should also consider whether you’re going to closed-loop
operation with oxygen sensors. They’re not difficult to install, any
exhaust shop can weld in bungs for the sensors themselves. The
biggest factor in that decision might be what sort of EFI you plan to
use and where do you plan to get the components. ECU’s that use
oxygen sensors might be easier/cheaper to find than ones that don’t.
I believe you’ll find that an ECU designed to run without oxygen
sensors would work just fine – good performance and fuel economy –
but using an ECU designed for use with oxygen sensors without
installing oxygen sensors would not, it’d run rich and get poor
performance and fuel economy and possibly even foul plugs.
Lastly are there any favoured combinations that are more or
less standards that tried and true?
A goodly number of people in your position would opt to swap out the
entire engine with an H.E., possibly including swapping the
transmission for a GM400. Might even go one better and install the
6.0 engine with the 4-speed auto. Either way, your fuel economy
would increase by an astounding amount, perhaps 50%, and in this day
and age of ever-increasing petrol prices we can all appreciate that.
The latter option, the 6.0, would also yield a significant
improvement in performance, although as MGuar would happily point out
you could improve the engine you’ve got if performance is what you’re
after.
As far as keeping the engine you’ve got, I think some might suggest
the simpler upgrade of swapping the Zenith-Stromberg carbs for SU’s.
I’m not entirely sure how much benefit there is to that upgrade, but
it seems to be popular.
– Kirbert
