In reply to a message from PeterCrespin sent Mon 29 Jun 2009:
Hello !
Well, it’s not Kirbert, but this trick works quite well : more than
often, the ‘‘Vs’’ on the pulley are slightly higher than theyr
conterpart grooves in the belt, thus mindering the contact surface
to the top of these ‘‘Vs’’, so ‘‘squeeeek’’
By grinding them, one can allow the belt to sit proprly on the
pulley, so a little more belt tension and no more ‘‘squeeek’’.
It can be made, depending of the pulley material, with sandpaper
fixed on a flat surface and turning the pulley by the hand if
alluminium or, if steel, it’s better to use a lathe.
By the way, my wife’s toy is the XJ SC, mine is a Defender … So,
been there, done that …
Cheers–
Wish I’d never posted on this thread. My Wife’s Discovery has
started squeaking again after only about 2500-ish miles on the new
belt. Will try a shot of dressing but am not optimistic for the
medium term.
Kirby, can you expand (or ‘contract’ LOL) onm this business
of ‘grinding’ the tops off the vee points?
Philippe, XJSC 87 Strasbourg
STRASBOURG, France
