In my quest to find a good XJ-S I drove another one today. It is an '86 model year that has been idle for five years. It idles well and runs well at lower RPMs. When I accelerated it on the freeway it would stumble at about 4000 RPMs. It didn’t die but it had a lot of trouble getting past the 4000 mark. Can anyone shed any light on what may be causing this problem?
In reply to a message from tom white sent Thu 27 Sep 2007:
Hi , did you try some fresh gas.Art–
That could be the secondary coil at fault. There is a ducelier single coil
as a direct replacement. A quick search will give you the part number.
Kevin
Brisbane QLD
Australia
74 XJ12L “Ted”
83 XJS “Carmel”
83 XJS “Joanna”-----Original Message-----
Subject: [v12-engine] High RPM stumble?
Thanks for the help.
Best regards,
Tom
A good possibility is that the front ignition coil (used only as a ballast) may be defective and/or disconnected from the rear ignition coil located in the “V”. I removed both coils in my '86, and replaced with a MSD 8207, see pics here: http://www.jag-lovers.org/snaps/snap_view.php3?id=1145838596
Regards…Jim Kocmoud, 86 XJ-S, Chicago/Daytona----- Original Message ----
To: v12-engine@jag-lovers.org
Sent: Wednesday, September 26, 2007 11:42:00 PM
In my quest to find a good XJ-S I drove another one today. It is an '86 model year that has been idle for five years. It idles well and runs well at lower RPMs. When I accelerated it on the freeway it would stumble at about 4000 RPMs. It didn’t die but it had a lot of trouble getting past the 4000 mark. !
Tom,
Another possibility is the fuel filters are restricted. I have
found that a restricted filter will hold a certain speed but a few
minutes later the engine starts to ‘‘mess about’’. The cure is to
back off the gass slightly. This will work for awhile and as more
crud covers the restricted filter the speed keeps going down.
On my '92 the external filter has a filter screen that never gets
contaminated. This is because the in tank 70 and 400 micron filters
catch it first. his is followed by the pump inlet filter which is
finer yet. That one cost me a bundle to find this out.
Noel
My ''88 had 2 coils and it woked perfectly. But both must be in the
circuit to get high RPM, as others have stated.–
