In reply to a message from DOZZER sent Sat 20 Jan 2007:
From what you are experiencing, and the lead up thus far, I’d
really take a close look at the connector that mates to the marelli
ECU, on the pin that is responsible for carrying the synch signal
to the fuel ECU (I don’t recall that pin number, off hand, but it
you need to know, I will look it up). Since you had water seepage
on that side of the car, that was responsible for the ECU being
toasted, I’d wager that you’ve got a corroded connection on that
particular pin, and perhaps others, too.
Note that if this signal is not getting to the fuel ECU, you won’t
get fueling. I presume you have either listened to the injectors,
or inspected the plugs after cranking to verify that no fuel is
getting there.
I can’t see, right now, why you would have multiple failures in two
separate systems (fuel and spark) contributing to your problem. I
suspect your fuel relay is functioning fine (you DO hear the fuel
pump come on and pressurize the rail when you roll the key to on
(not crank) don’t you? This can occur and the fuel ECU can still
not issue injector pulses, because these are tied to the marelli
synch output. No synch, no fuel pulses.
The connector housing on the Marelli’s cable can be opened
relatively easily; the pins are in there quite densely, though. In
fact, they are in there densely enough that it is easy for one wire
to break loose under strain; I want to recall the fuel synch pin is
located toward an end of the row…
Right now, my money’s on either a corroded connection, or a
corroded wire that has separated from the connector pin on the fuel
synch line.
Glad to see you are making progress!
Good luck,
Mike–
all the wires and sensors I replaced the spark ecu unit. AND
SPARK was obtained. But still no fuel injector click or fuel
Mike, 1990 5.3 XJS Convertible, ‘Caterwaul’
Lakewood, OH, United States
