Wrong list, obviously. Little to do with the V12 engine.
After renovating the fuel tank and getting the V12 back on
the road, I’ve been driving the car, and getting increasing
levels of fluid leaking onto the garage floor. I finally
got it on the lift, and had a chance to survey the
problem(s):
- Steering pinion leak.
On the XJ-S/12, that tower seal is available separately. It ain’t cheap,
though. Apparently it called for a special design for some reason. It’s also no
fun to replace.
- Steering gater leak.
There is no such thing as a steering gaitor leak, because they’re not intended
to seal. They actually have drain holes. They are only intended to keep dust
out. If there is fluid coming out of there, you have a rack leak. And if the rack
and the tower are both leaking, time to yank it outta there and have it rebuilt.
- Rear main seal leak.
That problem usually turns out to be a PCV problem. If the PCV system is
working fine, there’s little or no leakage from that seal, but if the crankcase
pressure goes up a hair, it starts leaking profusely. The condition of the seal
itself is apparently rarely if ever a factor. The old rope seal just doesn’t go
bad, apparently.
It is possible that what’s wrong with the PCV system is that the engine is so
worn and has so much blowby that the PCV system is overwhelmed. IIRC,
we’ve had at least one owner install a second PCV system, and he reported
that that actually worked, stopped his rear main leaks.
- Clutch slave leak.
- Brake reservoir leak.
The reservoir itself? Cracked? Or is the hoses connected to it that are
leaking? Nobody used regular gas hose to connect it up, did they?
- Speedo drive gear leak.
I dunno if it’s the same as on the GM400, but that little contraption had its
own little seal – and when I mentioned the issue to a transmission shop, they
showed me an aftermarket seal that was MUCH better than the OEM part!
The problem sometimes is the gear itself, though, with the shaft boogered up
enough that the seal won’t seal against it.
- Differential leak.
Pinion or output shafts? Leaks at the output shafts will lubricate your inboard
rear brakes, which is why I keep recommending an upgrade to vented rotors.
The ratio of work to road time has got to go
down with this car or I’'m going to pull out the little hair
I have left.
As I learned long ago, simply rebuilding stuff according to the ROM
procedures and using OEM sealants and gaskets will result in a Jaguar that
leaks just as much as always. These cars famously leaked on the showroom
floor. If you want it to STOP leaking, you have to take a more proactive
approach, thinking about what really seals and what doesn’t and how to
assemble components so they WON’T leak, period, not now or later.
Face it, your car is old and incontinent. But with patience, you can get the
bottom dry and the garage floor clean.
– Kirbert
Visit the Jag Lovers homepage at http://www.jag-lovers.org for exciting services and resources including Photo Albums, Event Diary / Calendar, On Line Books and more !On 6 Oct 2016 at 20:04, Lundabo wrote:
