Can anyone advice the dimension or ID of fuel crossover hose
used on fuel rail of 6.0L V12 please?
The car is 1994 Jaguar XJS v12 with Marelli
Cheers–
xjs v12
Bangkok, Thailand
I suspect the number Mr. Faircloth gave you is CORRECT. He did service my injectors and replaced the two hoses on my rail a couple of years ago. Yes, factory 6.0L V12
I got some 9.5mm fuel hose, and they need some persuasion to get on the fuel rail nipples
I didn’t want to use any kind of lubricant, by fear it could damage the hoses or help them get out later
no picture of the 4th one, but it’s about the same of the others
They’ve been changed before, and the end cups were lost / removed , and are unavailable for a while
I wonder if adding the same worm clip as before would be useful or not, most I’ve read was saying they could do more bad than good
as I send the fuel rails out to be powder coated, I can’t remember is the sensor fitting in the right rail is blocked or not ?
the rail came back like this
Is a bit late now…since the hoses are already fit in place…you can use an FI hose clamp…solid body…not a worm clamp type. The sensor bung is welded to the outside wall of the fuel rail…there is no contact with fuel. SD Faircloth www.jaguarfuelinjectorservice.com
thanks
those have limited adjustment, and probably won’t work if I try and open them more to get them around the hoses as they are.
SO I’d need to get the hoses out agin, if /when I can get the clamps. I measured the external diameter, which varies between 17.5 and 18mm, probably depending on the amount of stretching of the hoses around the barbs.
16-18mm clamps would be the best, just need to find some now (and a way to put the hoses with less efforts )
Look up FI clamps distributed by Ideal Tridon. Part # 52F1658. They are available at Advance Auto Parts. Clamping range 14mm to 16mm. Those work from my experience. Would be nice to find them in SS. To aid fitting the hose on the fuel rail barb, and only because they are tight, use a tiny wipe of Vaseline on the barb, and maybe run the end of the hose under some HOT water for 30-45 seconds and then shove on quickly. Now obviously the hose clamps need to be on the hose before you fit the hose to the barbs. To position the clamp down at the end of the hose, use a bit of Vaseline on the hose end to make it slippery. When the clamp is in position and tightened, wipe of any extra Vaseline. Gloves help protect your hand and fingers. SD
thanks for the advices : my thumbs still hurt from last fitting
as I’m in France, I probably won’t be able to order from advance auto parts, or delivery times will be enormous
I’ll try and find some locally, and will look for stainless, as I don’ t fancy another go before 10 years
Kirbert
13
Sittin’ around the design department one day. “What shall we do to piss off the customers this week?”
“I’ve got a great idea! Rather than just making hose fittings in standard sizes of 8mm and 10mm, let’s manufacture a really oddball size. Not even an even 9mm, let’s go really oddball and make it 9.5mm. For no damn good reason at all! That’ll not only piss off a lot of customers, if we’re lucky it might even cause a few fuel fires!”
“Oh, simply awesome idea! You’re overdue for a promotion!”
of course, fitting them needed to cut off and renew the hoses, but my technique improved and it took about 5 minutes to fit the new hoses, using my weight to push the hoses in, while the rail were on a piece of wood to protect the fixings
It was probably some bean counter who discovered he could get the hose for 3p a metre cheaper! And the stupid way they were attached rail? Again probably some stupid “ economic” decision having no basis in engineering whatsoever! We had to suffer this sort of s…t every day back in the late 70s particularly.
