Hi Folks!
The other day, I wrote…
The next day, while at speed (about 130 kph) it all of
a sudden started to miss, and buck. It went away, and I got off the highway.
As soon as I was going slower, it started again. She stalled. I started her
right back up, and kept going. Several hours later, the same thing happened.
I was driving along, and the tach started to dip repeatedly, and she soon
stalled. started back up no problem.
That evening, I tried again, and once she began to stall, the length of time
I could keep her running began to diminish. I headed back home, and she
stalled 15+ times before I got her back (less than 8 blocks!) I noticed that
it does not happen only under a load, she’ll stall at idle too.
OK UPDATE.
She seems to run OK for a while after she’s been sitting. I’m almost sure
it’s not the ignition amp, because when I drove her the 5 or 6 blocks to
Canadian Tire to get a HEI module, she stalled out just as I got into the
parking lot. I popped the hood, and the amp was still quite cool to the
clutch. (I didn’t bother with the module)
I popped the trunk, and the 2 relays near the ecu were pretty warm to the
touch (not really hot, just warm) is that normal?
I gave her a 15 or 20 minute rest while I wandered around the store,
wondering whether I should buy anything, then drove home, She stalled 3
times before I got to my parking lot, then 4 or five times as I tried to
park.
I think I’ll check the surge tank this afternoon, because it’s sounding more
and more like a fuel delivery problem?
I did indeed clean it all out several months ago, while trying to nail down
my 4500RPM “brick wall”, which ended up cured by a plug and wire change (and
cap, rotor, 2 coils changed before the plugs seemed to solve it) but it was
already pretty pristine to begin with even after 12+ years of neglect. I
suppose it’s possible I got some lousy gas?
What do you folks think?
Just before she stalls, the revs drop quite a bit, and she gets REAL ROUGH
and lopey, like a chev with a 1/4" cam.
barRUmphF barRUmphF barRUmphF…
Shift to neutral, restart, and back to drive, OK for a few moments, then all
over again. Once this behavior begins, the episodes get closer and closer
together, until it starts, and dies within a couple of seconds. (talk about
a LOUSY way to limp home, 20-30 yards at a time!)
-To unsubscribe go to
