I have not experienced this.
But it sounds like there is a blockage in the sump pickup pipe.
This sounds like the problem people have reported with their fuel pumps when
there is crud in the tank. Starts fine, as the revs rise, it sucks up the
crud which blocks the input filter. It stays there until the engine is shut
down and the crud drops back into the bottom of the tank.
In your case, there are 2 bypass valves in the oil filter block.
The main bypass valve (that you need a big spanner to get off) has a bleed
on the back, back into the sump via a tiny tube. I don’t know what this is
set for. It is reported to be 70psi, but I have measured one closer to
100psi. So there is a question mark over this.
There is also a small flimsy spring loaded flap valve that bleeds oil back
into the pan if the oil cooler is blocked. I think this is described as an
80psi pressure relief valve.
Oil is sucked from the sump, mixed with any return flow from the cooler
(directly at its inlet) and pressurised through the pump.
Output is fed to the filter block where the oil is exposed to both the
filter/galleries and to the bypass valve and relief valve.
Under normal operation, the bypass valve should bypass excess flow (that the
oil galleries don’t use) to the oil cooler, and from there back to the pump
input. If the cooler is blocked, then the relief valve should dump oil back
into the sump.
There is a case where the pump could cavitate, if the sump pickup was
partially blocked. This would put a partial vacuum on the pump inlet leading
to air bubbles forming at the pump output. Air bubbles result in the oil
being unable to apply any meaningful pressure, so I presume the pressure
gauge would drop.
Mark____________________________________________________________
When the engine is started the oil pressure builds immediately and is 40+
psi. As the revs are increased all remains remains normal until at around
3000 revs the pressure falls ba back to just a few psi. The pressure doesn’t
rise as the re revs fall.
If the engine is stopped for a while and the restarted exactly exactly the
same happens.
