Well I guess Welsh isn’t the solution. They are more expensive than direct
from the UK from some suppliers I use there.
I will look at finding a good general bearing shop and see what they might
have. I might have my father (a machinist) make up some sort of adapter
which might accommodate another type of bearing.
Patrick
82 XJS HE
EAC-3042 $112.84 IN STOCK!
YES IT IS FACTORY JAGUAR… I WILL SEND A CATALOG TODAY!
THANKS
BOB!
email: @Patrick_MacNamara
contactby: email
comments: Could you please quote the price for the bearing EAC3042 as
liste4d in your on line catalogue. Is it an OEM supplier bearing?
I would also like acatalgue and price list if possible. Thank you
[mailto:owner-v12-engine@jag-lovers.org]On Behalf Of Kirbert-----Original Message-----
Sent: January 31, 2002 9:13 AM
To: v12-engine@jag-lovers.org
Subject: RE: [v12-engine] Re: Jockey Pulley Bearing (was Update on
Cooling System)
Patrick MacNamara wrote:
Actually,
I just checked out their website and they do list the bearing!
EAC3042(pg I05 in RTC9900CA) and I have emailed them for a quote. It
does look quite a bit like the water pump bearing but has a different
part number!
The bearing on a water pump has the shaft sticking out both ends,
with the pulley going on the front end and the impeller on the back
end. The bearing in the idler and the bearing holding the fan clutch
are similar bearings except the shaft only sticks out the front end.
If that’s the only difference, you could use the same bearing and
just cut the back end of the shaft off. However, there are LOTS of
other things to check, including OD of bearing, length of bearing,
press fit diameter on shaft, length of shaft, etc.
Besides, using a bearing from a Jaguar water pump would be expensive.
I suggest using a bearing from a Chevy water pump, which use similar
bearings but the entire water pump can be had for less than $30 or
some such.
– Kirbert
-To unsubscribe go to
