In a message dated 4/24/2000 5:24:14 PM Eastern Daylight Time,
bebeep@mediaone.net (Tom Drakos) writes:
<< I plan on trying to blow the line out and see if anything comes out. >>
Good!
<< Where does it connect under the hood. >>
Umm… I dunno. But rest assured, it’s the only vacuum line attached to the
ECU!
<< How do I know which one to disconnect before I blow it out. >>
If you unplug it from the ECU end, and apply compressed air, the other end
should pop off under the hood. Might be helpful to have someone else watch
for a snake rearing it’s ugly head underhood during this procedure.
<< Can I just suck on the ECU side to check for the Map sensor leak. >>
Well, I suppose you could. However, your tongue would not be sensitive
enough to detect a significant pressure differential over a prolonged period
of time, and you might wind up with a “tongue hickey” as well, which isn’t
particularly healthy.
<<Should it hold a vacuum if I suck on it? >>
Yes, it should. However, it would be much preferable to utilize a vacuum
gauge and apply roughly 30 in. hg. to it, and see how long it can hold that
much vacuum. If, starting out from 30 in. hg., it can hold within 10% in 5
minutes, I’d say that it’s OK.
<< My gas mileage has been terrible since I’ve owned the car, which has only
been about a month or so. If it has been the vacuum to the ECU all along, and
causing it to run that rich, I suppose I may have burned up the Cat’s with
all that excess fuel.>>
Rather than “burning them up,” I suspect it’s much more likely that you’ve
coated all of the ceramic balls with a very heavy layer of carbon, which has
now glued them all together in a near-solid mass, and there’s nary an exhaust
gas path in sight.
<< If so, aren’t there some after markets that are not as expensive, or do
you know. >>
There have been previous threads about low-cost catalytic converters which
you can search for, along with other threads about removing them entirely
with something like “maintenance bypass” pipes; something I neither recommend
nor condone due to Federal emissions requirements. However, if you’re doing
some “bracket racing” or “circuit racing,” you may be able to convince your
local muffler shop to weld you up some “bypass” pipes, with the understanding
that these pipes will never be used on the street. :o)
Hope this helps…
Steve Wilke
'88 XJ-S H&E Conv.,57kmiles
