[v12-engine] Stumbling idle & acelleration and location of Thermotine switch
1984 XJ12…VDP in Canada. Manuals indicate a thermotine switch on the
thermostat housing of the passenger side of engine. No thermotine in
sight…where is it? Can it be there isn’t one?
And…terrible stumbling at idle and, during acceleration. Vacuum is a
bit low but seems OK, new dist. cap(old one blew up while jumping
battery). Temperature outside is -20C
Where’s the thermotine?
Larry Bruder, Canada
In the past…49MkV saloon, Xk150S Roadster, 63 E-typeOTS, 64 E-typeFHC,
66 E-typeOTS, 78XJ6, and now my new affliction…84VDP
-To unsubscribe go to
On 28-12-01, Larry Bruder told us:
The thermotime switch disappeared at VIN 114474 (XJS) and VIN 377726 (XJ12)
along with the cold start injectors. (around Feb 1984).
This is not related to the thermotime switch. This could be any of the
usual culprits, such as throttle potentiometer, blocked fuel filter, bad
ignition amplifier etc.
Is the misfire equal on both banks? is it worse with the engine hot or cold?
regards,
Mike
