Hello Troy,
The hose from the supplemental air valve is indeed a molded item, it is
Jaguar part no. EAC 4096 1, while
you’re at it, you might as well replace the rubber grommet it fits into,
Jaguar p/n C 16393. I know this because
a previous owner had replaced the molded item with a straight hunk of 1/4"
hose, which over stressed the
rubber grommet.
As usual, I was NOT satisfied with the fit of the OEM hose into the manifold
port, so I purchased a plastic
elbow from Discount Auto and with a short hunk of 1/4" hose, arranged a neat
right angle routing of the hose.
Of course, you could probably do the whole thing with 2 plastic elbows,
about 16" of 1/4" hose, and a grommet
from the “HELP!” parts section at D. Auto.
There is more than one way to skin a “cat”!
-Don Buresh, 1991 XJ-S V12 Coupe, Classic Edition, getting a nice NEW
radiator this weekend!----- Original Message -----
To: v12-engine@jag-lovers.org
Sent: Thursday, March 29, 2001 6:50 PM
Subject: [v12-engine] Suplamental Air Valve hose
Several people were able to help me identify the supplemental air valve on
my car. Well while fooling with it the hose that runs from it to the
manifold snapped like a dry twig. One person that told me what this was,
indicated that his, is in his attic. My question is, is that alright? I
would really like to hear from someone that knows this engine on whether
this item needs to be in there or if I can just plug the outlets and do
away
with it. I know that even though Jaguar put it in there it may not be
necessary. On the other hand I am to chicken to just leave it out and see
what happens. With this car it would probably run perfect for a couple
hundred miles and then blow up. I can just hear the wrecker driver, “Only
time I ever saw this was when the dummy left his SAV unhooked.” Finally if
it is important can anyone tell me what type of hose to replace it with?
It
looks preformed but I assume you can use some type of generic hose.
Thanks, Troy
88XJ-S
-To unsubscribe go to
http://www.jag-lovers.org/cgi-bin/majordomo
