In reply to a message from Ronbros sent Sat 26 Feb 2011:
Ron,
No, sorry! The flat head has no combustion chamber the HE has the
exhaust valve recessed in a chamber of about 30cc according to a
number of people. So using the HE pistons on a Flathead would
yield like a bizzilon to 1 compression ratio. (I might be slightly
exagerating. silly grin) Oops don’t forget the valves stick
slightly proud of the surface on the flathead My memory is foggy
but I think it’s about 7 cc when you subtract for the spark plug
recess and add the height of the valves…(it’s early morning as I
write this)… So figure about a bizillion .8 to 1 (another silly
grin)
The combustion chamber is in the piston on the flathead. stock
pistons were 7.8-1 9.0-1 and 10.-1 (last half 1980 in europe)
Under the exhaust valve on the HE (in the head)
Your idea of pressure forcing the exhaust out? Doesn’t work that
way! On intake under turbo pressure piston going down. Intake valve
closes Piston comes up on compression, piston goes down on power
and exhaust valve opens and piston comes up on exhaust… events are
too far apart… as for overlap? on a stock camshaft? Besides
you can’t have overlap on a turbo motor! That’s one of the no-
no’s Exhaust Pipes go from white hot to none existant with
overlap…
OOPs!! You don’t understand the purpose of the computer
program! You plug data into the program, turn on computer,
computer assembles and runs the engine (Cyberly) prints out a real
dyno sheet…
If you have good data* you will get accurite data out… correct
within 2% (you’ll get more variation from run to run on an actual
dyno)You can confirm you have good data by running the engine in a
stock configuration and the power output should match the stock
power output. If off slightly adjust untill the numbers duplicate
the stock numbers… (published lots of places)
The program I’ve used for decades now is constantly accurite. I
used to do the program and then run things on a superflow dyno and
constantly I was accurite… Mines an old Engine analizer pro
while the new one seems to be a lot more user friendly.
Want to build a 10 litre V12? won’t cost you a dime and you can
see actual numbers… then want to supercharge it? Run a set of
Webers, 3 holley’s, a partridge in a pear tree? (opps now I’m
getting silly)
I’ve got a lot of flowbench numbers I can give you, Borrow some
junk HE head and spend $10-$20 getting flow bench numbers. (only
have to do one intake and one exhaust) That’s the only data I can’t
give you… The Fuel injection manifold already has numbers
published for it both stock and modified…
Oh, and if you want you can also take a stock exhaust manifold and
put it on the flow bench to see how nice that flows…
OOPs running out of space, Don’t forget if you have the turbo’s
below the crank centerline you’ll have to figure a way to get the
return oil back into the oil pan… Some kind of pump…–
MGuar
Wayzata Minnesota, United States
