In reply to a message from BobPhx sent Mon 9 Apr 2012:
the early BW V12 mounting alignment dowels different from the late
77 onward that was an actual GM dowel locations, it was the same as
an old Chevy V8 from 1955, now how far onward the GM dowel
dimentins, was carried I do not know.
( someone may have that info), ques. do the 6L block use a GM dowel
pattern?? even tho the bolt pattern may be different?
the bolt holes where the bolts go thru to the block, are off also,
i used a flat plate,BOP GM, with the dowel holes allready in it.
giving perfect alignment of block,plate, and transmission.
then drilled the bolt holes and chamfered them to flush mount the
socket head bolts, the plate had a Chevy bolt pattern on it, and I
run porper length bolts, so I used a Chevy van 700R4.
must be OK been 16yrsā
The first production auto-box behind the 5.3 V12 was the Borg
Warner, no?
The 5.3L bolt pattern never changed, afaikā¦ so I am wondering
if the bolt pattern was originally some sort of BW standard.
ā
Ronbros
daytona fl. / Austin TX., United States
āPosted using Jag-lovers JagFORUM [forums.jag-lovers.org]ā
āSupport Jag-lovers - Donate at http://www.jag-lovers.org/donate04.php ā
