At 04:07 2003-01-15 +0100, Rando wrote:
What will I have to do to fit an 88 XJ12 V12 in my 71 E type V12?
Same mounts or not?
It is supposed to be the very same block, so I don’t see why the mount
points would be different (the part for the mount themselves might be,
WRT how they bolt to the car, but I doubt that).
Can the intakes from the 71 4 carb. engine be used on the fuel injected
H.E. head? What about on a pre H.E. fuel injected head?
The injectors tap into the intakes, not the heads, so I’d have to say
yes, but then I’ve not checked out a V12 from the E-Type era. The
differences (if any) between the Pre-HE head and the heads from an E-Type
are probably nominal - if anything, the compression and valves might be
slightly different, but those don’t affect the intake.
Of course, with enough determination and ingenuity, you could manage to
mate them even if they normally wouldn’t simply bolt on.
Call up your local Jaguar dealer and inquire about the part number for the
intake manifold gaskets for the E-type application and the XJ12 (or XJ-S)
application. I suspect that they might be the same (both having been
superceeded to the same newer part). That’s only a guess on my part, but
it’s what I suspect to be the case.
I bet given some time that you could find someone on the JagXchange parting
out a V12. Heck, if you hit the archives here, I recall mention on V12 or
XJ-S inside the past three months, someone talking about a bad head they
had – pay shipping and something for the head, and you could have
something in hand to bolt your intake to and see it first hand. Last year,
two separate vendor participants on the XJ-S/V-12 lists posted up V12
engines or significant parts thereof for the taking.
— http://jaguar.professional.org/
Sean Straw '88 Jaguar XJ-SC 5.3L V12 (LHD) ‘Black Cat’ 65K
Marin County, California '85 Jaguar XJ-S 5.3L V12 (LHD) ‘Bad Kitty’ 210K
'69 Buick GranSport 455 V8 324K
