In reply to a message from Kirbert sent Tue 16 Dec 2014:
been reading about this, with the V6 turbo engine, it turns
out it was a Rover engine, 6R4 metro, the history says it was
originally a 1962 GM aluminum 215 cu.in. V8, rover bought
rights to the manufacture it along with machineries,from good
old GM.
they B/L/rover made the deal with Buick/GM.
the basic engine was also used in the Oldsmobile F-85 cars and
some were the 1st a mass produced Turbocharged car(and the ist
car to use water/alcohol injection system 1962).
BUT( and this is a big history), the 1st GM aluminum 215
cu.in. was a concept car in 1951, GM Le Sabre concept(wiki )!
engine designed in the late 1940s, it was supercharged, and it
also used an alcohol injection system.
talk about being ahead of the curve,GM is number 1, Jag would
never afforded R&D for transmission and thru the years many
other components,(power steering pumps,Dana 44 rear(with power
lok).
my car has a modded posi with 1959 Corvette friction plates in
it,(thank to a photographic memory), they fit in perfect,and
gives a nice tight limited slip, for driving sideways,and
smoking the tires!
and to add to the history, XJ220 may not have had the metro
6R4 V6 turbo if Thom W.TWR hadnt had major influence with Jag,
and just happen to have the engines already made up!!
so the XJ220 actually has something in common with a 1951 GM
car.
what long strange journey this has been!–
I’m pretty sure it wouldn’t fit. I think the original V12-powered
design was significantly longer.
Prior to the intro of the XJ220, Jaguar was having tremendous success
in racing, running both turbo V6 and NA V12 cars. IIRC, the NA V12’s
were used for the longer endurance events because the engine had been
Ronbros
daytona fl. / Austin TX., United States
