Are the twin coils on my 1981 XJS HE V12 5.3lt the same for the
main and aux. I have a Jaguar CD telling me the part# is 35C6 (2
off) but cant locate this number. On a differen thread I read that
part # DAC2692 and DAC2693 are correct for the HE model. The 2692
is available on Ebay but the 2693 is not ? Any help to put this
matter to rest appreciated–
1981 XJS Man
Melbourne, Australia
Kirbert
3
main and aux.
The secondary coil, the one in front of the rad, has the HT terminal
plugged with epoxy. Hence, it has a different part number. You can
replace BOTH coils with generic bottle-shaped (oil cooled) ignition
coils with a primary impedance of around 1.2 ohms. Such coils are
very common and very cheap, like less than $20 each. For the
secondary, just fill up the HT terminal with epoxy, or silicone, or
something else similarly insulating.
– Kirbert
Visit the Jag Lovers homepage at http://www.jag-lovers.org for exciting services and resources including Photo Albums, Event Diary / Calendar, On Line Books and more !On 16 Apr 2014 at 22:36, 1981 XJS Man wrote:
In reply to a message from Kirbert sent Wed 16 Apr 2014:
Thanks Marek @ Kirbert
I understand now ie
Part # DAC2692 is a Jaguar number
Part # DLB170 is a Lucas number
Part # 11791 is a Standard number
I also forgot about the Aux. coil redundant hole to be
plugged but in my case I have the black rubber boot covering
that area and will also plug it up with silicone. Both coils wll
be 1.2 ohm primary indepandence.
