In reply to a message from Mark Eaton sent Thu 28 Jul 2016:
Hi Mark:
The HC and CO were BOTH ABOVE the norm. ONLY at idle.
2500 rpm test was good.
That was July 12.
Fast forward 2 weeks. The car was running beautifully and I
took her on a long 800+ miles trip.
Those were the results upon my return:
http://www.jag-lovers.org/v.htm?id=1469410491
My posts from Tuesday July 26 (after over 50 fresh gallons
of fuel) contained the following possible explanations:
- The test equipment was contaminated two weeks ago, now
was in proper order (unlikely, but…) - I drove the car 850 miles between then and now. Must have
cleaned some gunk. Very likely old/bad fuel contributed
too. - There was an ignition system fault somewhere – plugs,
rotor, wires, cap. (the misfire must have been gross and I
would have noticed btw). The fault was corrected when I
pulled/replaced the plugs and reseated the wires. - Clearing the memory from the ECU did the trick. Perhaps
there is a bad capacitor as suggested earlier, perhaps the
idle trim does things to the mixture nobody can understand.
In my view, this is the most likely reason for the pass
today.
Steve–
Personally, I think you have a lean misfire under closed loop (learnt
correction), not a too rich mixture.
The high HC thing with normal CO suggests a lean misfire. And if the default
settings are richer (as Kirby suggested) then your idle will smooth out
after battery disconnect.
Didn’t you put fresh fuel in? Did that coincide with your passing the
emissions test?
'95 XJS convertible - V12 6.0L
