‘Static’ means the engine is stationary, Christophe - it is not usually specified…
To illustrate ‘how’ it is done; with mechanical points the ignition occurs as the points starts to open. The engine is turned to the specified static advance on the damper, the distributor clamp is loosened to allow the dist to be turned. A cigarette paper, or similar thin tissue, is placed between the the points, and the dist is slowly turned until the paper just falls out - indicating the points is just about to open…
With electronic ignition; the ign is triggered by a signal from the dist pick-up - but the idea is the same. With the coil center lead placed some 1/4" from a good ground, the dist is slowly turned either way, back and forth, to trigger sparking - and the dist is clamped in the assessed ‘best’ position. With a vernier fitted; in all cases the vernier is set in the mid position - allowing final tuning either way with the engine running.
However, ignition must occur on the cylinder thst is in the firing position - on its compression stroke, and the rotor must point to that cylinder. On all 4-stroke engines the TDC mark on the damper indicates two different states - the ‘right’ or the ‘wrong’ cylinder with reference to the rotor. So the ‘right’ cylinder, the one the rotor is pointing to, must be verified to be on the compression stroke…
The ign sequence of the V12, the right bank is the ‘A’; 1A-6B-5A-2B-3A-4B-6A-1B-2A-5B-4A-3B. So set to TDC; the rotor must point either to 1A or 4B - the 1A is preferred as a reference cylinder. But it is very important to verify that the 1A is on the compression stroke…
…and the best way is to remove the 1A spark plug and turn the engine while holding your finger on the plug hole (no mean feat alone!) to feel the compression as the piston comes towards the TDC mark on the firing stroke. You can use a cork, or whatever) to plug the hole - as it pops you know you are on the compression stroke. The rotor will now point to 1A - or rather; the 1A plug lead must(!) be placed there on the dist, as a reference point for the ign sequence. And the rest of the leads placed from there counterclockwise in the described sequence…
Without specification on static timing, you may set 5 deg BTDC on the damper; it’s a bit iffy - and proper timing must be set to spec with the engine running. It may be done with the vernier, but if the range of that vernier is insufficient, the vernier should be ‘midpointed’ and the distributor position altered accordingly…
Of course, if the engine is running; there is no point in using unspecified ‘static’ adjustment - though as a crude starting point, anything from 0 to 5 deg BTDC deg to get the engine running, then set the spec advance. That the engine will not run may be caused by other factors, like wrong ign sequence or whatever - not to be neglected…
Frank
xj6 85 Sov Europe (UK/NZ)
