Hi forum,
Some months ago, I bought this '78 XJ12 from a talented retired engineer, who did a complete resto on it for something to do. He built it his way, with S1,2and 3 and Euro stuff on it. He swapped in a complete HE engine and ECU and harness, and…drum roll…an E Type 4 speed. It has side exhaust, and an AJ6 enhanced ECU, programmed for no-cat use. Cool stuff, but, it’s running very rich. A set of plugs lasts a couple of start ups. I changed the oil for fear of fuel contamination.
I wish I could get this baby to run right, I want to see the results of the performance work. I did drive it 2 hours home after swapping plugs, and it was nice to shift gears, but it bogged with anything over 1/3 throttle.
Keep in mind and with a complete resto and swapping parts around through the years, anything could be wrong.
So this is what I’ve done:
- swapped ECU’s - no difference
- CTS seems in spec, tried jumpering the plug, and verified the harness is reaching the ECU
- added O2 sensors, there weren’t any! and verified the harness is reaching the ECU
- Throttle switch reads good though the range
- both full load switches working, and the harnesses are reaching the ECU
- cleaned power resister plug
- vac tube from balance tube is reaching the ECU, and engine bogs out when it’s disconnected
- Good spark, NOID light shows good pulse.
Today I had a tech come again, and he noticed during cranking, there’s no vacuum on his gauge at the intake. This could be fuel washed down the bores, or bad cam timing, or intake leak. I tried another V12 ( a friend dropped by) and the gauge showed 5-6 pounds vac
during cranking before it fired. Coincidentally I got a smoke machine recently, and pressuized the intake with smoke. I only found a minor vac hose leak. I did a compression test one one easy cylinder, and got 175 as is, and 200 with a tablespoon of oil. So, it seems like 175 should start the engine, or create vacuum. I guess to rule out fuel wash causing the no vac, I should put oil into all cylinders and test again.I know the engine builder, and he’s done hundreds of these engines, so I’d be surprised if the cam timing’s out. But, I’ll remove the cam covers if I must.
Any help is very appreciated,
Cheers,
Rob
