Vacuum connections
Where are the vacuum connections on the intake manifold on the 3.4 engine
On the back of the inlet manifold and a small pipe from the front carb to the distributor.
But on a SP head the manifolds have one at the middle of the underside. ( 240/340/420)
Look for vacuum leaks along any of these lines. You could easily be leaning out your engine if there is a leak.
