The point is whether that spigot delivers ‘manifold’ or ‘ported’ vacuum, Con - best checked at the distributor vacuum hose with the engine running…
The external location of a spigot doesn’t necessarily confirm the vacuum it delivers - just check to clarify. It’s a bewildering range of advance settings between model years/markets - but assuming you have an original Australian 85; the 4 deg is relevant. And it indeed implies that it should have ‘manifold’ vacuum at the dist vacuum hose…
The difficulties with positioning the dist for 4 deg advance may have various causes, but basically my be the choice of plug lead connections to the dist lid.
Turn the dist so the vacuum spigot points rearwards for nearest connection to the vacuum line. Set the engine to TDC mark and remove dist lid and note position of the rotor. Rotor must now point to the #6 (frontmost) or #1 (rearmost) plug lead. Hand trace the leads from lid to the relevant plug to make sure…
Nominally; the #6 lead is around 5 o’clock and the #1 at 11 o’clock, looking down at the dist. However, if the dist is put in at different positions; the position of the rotor will be stationary - but will point to different holes in the lid. As the #6 lead (reference cylinder) must(!) be placed in the hole pointed to by the rotor - the vacuum capsule (or whatever limits the travel of the dist for initial ign timing) may point ‘anywhere’…
Ie; verify what is limiting the counterclockwise turning of your dist. Then reposition the dist and visualize if moving all the leads one step on the lid - or move the leads on the lid. Then turn the dist to turn the dist to make the rotor to line up with the #6 lead.
In other words: While turning the dist the rotor direction remains fixed. But the rotor must point to plug lead of the cylinder ready to fire, which is #6 or #1 depending on which TDC the engine is set to)with the engine at TDC. And the initial position of the dist dictates the adjustment range of turning the dist for ign timing…phew…
That said; you don’t mention if the engine is misfiring, which may indicate ‘crossed’ leads. But verifying ignition sequence is a good idea - particularly if the plug leads have been disconnected.
Having placed the #6 lead; place the next leads counterclockwise on the dist lid in the ign sequence 6-2-4-1-5-3. (Or, if the engine is set at ‘the other’ TDC; 1-5-3-6-2-4). In the process; hand trace each lead form the plug to the dist lead and bac - it’s incredibly easy to get lost…
If all this does not solve the timing problem; David’s input about the pointer/scale on the damper being misaligned is relevant - in which case the advance cannot be reliably set. You absolutely need to check this; remove the #6 spark plug and turn the engine to bring the piston up to its highest point - using a rod, or whatever, to verify.
The piston is now at TDC - and the pointer at the dampers scale should read ‘0’. If not; the damper might indeed be adrift, which require replacement - or the pointer might be bent/displaced. The pointer/scale must be correct for any meaningful advance setting work! Do this before proceeding - the engine is indeed easier to turn with the spark plugs removed…
As an aside; increasing idle will not(!) solve the timing problem…
Frank
xj6 85 Sov Europe (UK/NZ)
