I accidently pressed the valet service button and cant find my key to disable it, any ideas?
So yo mean the only key you have is the green valet key?
The only way to disable the VALET MODE is to manually (or by keyfob remote) open the boot lid and have it RECOGNIZED by the vehicle. The boot light needs to come on or INST PK indicates BOOT OPEN or TRUNK OPEN.
A faulty boot lid switch will NOT disable the VALET MODE. I have had to manually ‘short’ the switch connector when the switch failed to disable VALET MODE on many customer’s cars.
The BLACK MASTER key will open the boot lid if you have not neglected the lock and had it seize with debris or corrosion in the mechanism. I use my key about once a month to ensure that it works in case I need it to.
bob
Thank you very much for your helpful reply, I will do as you mentioned
today.
Len
