Would anyone know the relation of the Woodruff keyway on the vibration damper to the COMP marking or to the TDC?
I have disassembled my Vibration damper for my XK120 & my e-type and unfortunately I have not marked the relation between the outer ring to the inner one.
I would like to rebuild it now, but cannot do it without knowing how it’s assembled.
Tadek
My memory is possibly playing tricks but I thought… both the crank and cone that the damper mounts onto are keyed?
Right, but the 2 parts of the damper, which are separated by rubber are of course not.
I have cut the rubber, cleaned it, and it’s ready for rebonding, the question is just where should it be rebonded…
You could put engine to TDC, no 6 , front piston at top of compression stroke , then fit the 2 parts to the damper and mark them !
Ah. Ok didn’t see that. My initial thought is to set the engine to rev then temp fit every thing. Mark the damper where it needs to be then etc etc etc
07714 759198
I could, but my engine is seized and not rebuild yet…
