VIDEO... Indicator switch strip
Thanks to Eric for his earlier post on the function of the wiper switch . I got my switch fixed , but still no indicators . The little flasher unit does not test as it should . The square relay does click when the switch cancels .
Jim,
I drew this diagram a while back. It may help you sort out what’s going on in the DB10 unit.
Good news and bad news …All the indicators work after replacing the small relay , but the switch has gone down to a 3 second activation . Any fixes ?
Jim,
There is an adjusting screw but it didn’t make much difference to mine. If it hasn’t split, you could try treating the leather washer with something to make it more supple and seal better.
Eric
I have had another go at the switch and has worked for a few days without fail .
