Iām not sure about using the chromed top rings, never quite happy if they ābed inā properly.
You questioned if the second ring was iron, yes they are cast iron as are the top rings I think you will find.
The rings in bag 4 are old style oil control rings/scrapers, the spreader and two thin rings are the later type.
Correct regarding the colours needing to be visible, if they aināt youāre not getting that piston in the bore
Unless in a brand new bore, I would never use chrome rings.
Had to eat a few overhaulsā¦ and engine aint tasty.
Thanks for the advice .
I have emailed Grant to see what they suggest .
Looking at their web site they offer 2 versions of chrome plated , steel or cast iron . The ones I have are cast iron .
Again, unless they are going in pristine, new boresā¦ Iād go with cast iron.
I have now bought a new iron āHastingsā ring set . Thanks for the tips.
This is the message from āGrantā , from the vice president no-lessā¦
Chrome Set is for premium and required good honing finished in order to use Chrome rings of the set.
Please see attached recommendation for honing.
If you are not capable then use Plain top ring which is under part P1145 instead of C1145
The following is general information only. For more specific information please refer to OEM specifications and or your rebuilder specification guide.
Cast Iron Rings:
Leave at least .003ā stock to be removed before final bore size. Boring can sometimes leave roughness as deep as .003ā. In order to end up with a proper finish, enough material should be honed to remove all torn and folded material.
Use a 220 grit stone and remove .002ā to .0025ā of stock.
Remove the final .0005ā with a 280 grit stone. If necessary polish briefly with a 320 grit stone being careful not to burnish the surface.
Chrome, Steel and Moly Rings:
Remove the final .0005ā with a 280 grit stone and polish briefly with a 400 grit stone being careful not to burnish the surface.
Surface finish roughness should be between 20 to 30 microinches Ra. Ra is a surface roughness unit that is the arithmetic average of the peaks and valley depths expressed in microinches.
20-30 microinch average
Uniform cuts in both directions
Cross hatch angle 45Ā°
Clean cuts, free from torn and folded material
Plateau to be Ā½ to 2/3 of surface
Free of burnish and glaze
Free of imbedded particles
Free of excessive void
I also used Hastings ringsā¦ the oil scraper is MUCH easier to install as it is a one-piece design.
I have had another email from Grant from a different person. Take your pick .
" Thank you. Of course for any new rings the cylinders should have a clean bore. People still have the misconception from a long time ago when chrome rings were different. Todayās chrome rings are lapped and seat in easier than before. They may take a little longer, but will seat. As long as the bores are in good shape you should be fine."
That may be true: IME, after about 3000-5000 miLES, on the three disparate engines (BMW, Jaguar, and Datsun) I used them in (all āgoodā bores, that cleaned up well with a ball of stone hone), all three smoked like mad, and had poor leak downs.
Rebuilt with iron ringsā¦perfect.
Try the chromes, and let us know how it goes!
