It does have a few small changes to the wiring harness, most notably is an extra chassis harness that runs to the rear to run the two fuel pumps and a different connection into the ECU. I don’t know if that would require a change to the socket that is causing the problem seen with the brake lights, or change the power distribution to be different so that it us under less stress.
