I’m looking for a gearbox from a series 2 late 4.2 or 3.4 (which has the lower 1st )
I have an old disassembled 4 speed box that a racer guy threw in when I some other parts (about 15 yrs ago). Are there any particular marking to look for?
Hi - The most useful information is the letter prefix of the gearbox number. The number is stamped on a tag attached to the left side of the casing and also on the top cover.
Thanks for the info about the gearboxes
I wasn’t aware there was a Jag 5 speed- is that the rover LT77 (series 3 XJ), or is it a Jaguar 4 speed/ electric overdrive (in which case what’s the letter prefix on the gearbox number?)
The 5-speed Getrag was used on AJ6 engines, not on the XK. The 5-speed used on the 4.2 S3 was a modified Rover LT77 gearbox. Before that it was Jaguars own 4-speed, with or without the electric overdrive. If being fitted to an XK engine you really want one of the ones where the bellhousing fits, i.e. the latter 2.
I dont record KGN gearbox prefix, thus must be some rather obscure application, but the K prefix letter consistently tells you the ratios, and the N suffix tells you it is a Gearbox that provides for an attached OVERDRIVE (re output shaft/rear gearbox cover etc)…
The KFN gearbox, as fitted to XJ6, has the following ratios, which will be same as this KGN gearbox…
Thanks Roger
I also cant find KGN (and note your very helpful document)
There was a KGN for sale here in 2019, apparently from a 4.2 XJ6. Not sure if its the early 33/15 first or the later 34/14 one- i rather suspect the latter
It is a Jaguar 5 speed with the fifth gear being an overdrive gear from a series 2 or 3 XJ. I bought the transmissions from Peter Crespin of The Jaguar Journal some time ago for a couple of projects and probably only need one.
