To the best of my knowledge, the heater valve is not available, and any used valve is suspect. I found this one to be a perfect functional substitute, of course, not “correct”:
Make sure you get the “normally off” version. I initially got the “normally on” and only later found this one. If you find an nos item, better snap it up. I think the last time I saw one, it was $150, whereas the one above is $13 with free shipping.
Used ones come up on Ebay, be patient,
dont know how you propose to fix it ?, but await with interest !
S1 XJ item is very close
My heat cool system is incomplete, and modified, so I havent worried about an original heater valve (as used ones are likely to be failed, and new is NLA), not cheap either
As to the correct battery case, good luck,
I have been trying for years, no luck, wrecked 2 cars and it was absent, also from mine, it takes a larger battery.
I have a S1 XJ6 item with standard size (but 620CCA) battery
It would be possible for me to fabricate the correct sized item using two XJ6 frames, and not one sausage would know it wasnt original
try contacting a specialist Jag wrecker
I think people got jack of having to buy larger and more expensive batteries, so replaced them with cheap generic hold down clamps for standard-sized batteries
The old part would have got lost of thrown, I would probably pay $200 for a good original, with correct clamps
