I am just getting into a car that has not run for a long time and found significant corrosion in the thermostat housing and water outlet. If anyone has a serviceable set, please let me know.
Here are pictures of my corroded set.
Thanks,
Doug
Thanks,
Doug
IIRC, there are a couple different housings: post a picture of the corroded one.
Wiggles,
I edited my original to include a couple of pictures. Thanks
Actually, worse come to worst, with proper use of J-B Weld, that can be used, safely.
Agreed. Reparable, after bead blasting to get a clean surface to bond the epoxy to. Iād be inclined to use Devcon 10610, though. Pricey, but the best option to rebuild aluminum castings in my experience.
