I have recently purchased a Mk2 and notice that the washer hose to the washers is not connected. I have looked all over to see where it goes but have had no luck. The pump works, but the hose is not connected to the washers. Any help would be appreciated
Should be 2 plastic hoses connected to the bottom of the washers , then a T joint ,then 1 pipe that runs along the top part of the bulkhead inside the car , to the pump ,
It’s very hard to see the underside of the washers ,
Take the trim out that’s above your knees , then get your head right down and look up , with a torch you may see them , or with luck the plastic pipe !
Thanks your help I’ll start searching:+1:t2:
