hi friends, jaguar and type 2 + 2 1970, c15472 temperature gauge indicator instrument substitute signaling much higher grade, c16895 equal gear test signal higher temperature indicator where to be problem, many thanks
Giovanni,
Hai cambiato il trasmettitore sul motore oppure l’indicatore sul cruscotto della macchina ?
Marco
no, the engine light bulb replaced, now a very high signal perhaps false mass? Thank you
Try running a wire directly to ground (massa) from the gage .
I don’t recall (from previous posts) if a disconnected transmitter wire will give a high coolant temp or low…
Marco
Glad you found it. Since the problem was the voltage regulator you probably had issues with the fuel gage as it’s voltage is also supplied by it.
Marco
