Just in case someone is in the market for triple Weber’s. Needs a linkage and other bits but not a bad start. Carbs are made in Italy instead of Spain like some I’ve seen.
I SHOULD ADD THAT I HAVE NO INTEREST IN THIS SALE. JUST THOUGHT SOMEONE MIGHT BE INTERESTED.
Robert
Interesting. Like most of us here, I’m aware of the need for the tilt, or downslope, of the SU manifold on an E, but since the Weber’s are almost horizontal, vs the SU’s which are fairly tall, is the same tilt required to create space?
I’m not sure that’s an E-type set either. I had one for my car, never installed, sold in '02 but this was the drawing that came with them for installation.
Here’s the photo from the ad. Looks like the same brand of manifold. And the bolt pattern on the head side looks right. Fuel line connection looks right, but the center carb has a throttle connection on the “wrong” side? Is that connector reversible to the other side of the carb?
Matching 45DCOE bodies looking at the stampings although why the ram tubes and filter mismatch?
Possibly these were fitted in a car without enough inner guard clearance for the front carb (which has incorrectly been put in the middle for the photo). Mk 2 Jag has this problem with triples; XK series might as well.
Throttle arm positions and fuel feed are all pretty modular on Webers so I wouldn’t read much into that. There is no throttle linkage and the devil is in the detail as that is going to have to be made, which isn’t always easy, and the cost for the parts is not insubstantial.
I can’t comment on the manifold apart to say that the Webers sit lower than SUs and the manifold looks straight out from the head so it might all fit under the E type bonnet. Stud pattern looks ok.
Final problem is that the whole lot needs to be rebuilt and THEN tuned to your car.
Looks cheap, but to get it running on your car, assuming that the carbies aren’t damaged (air bleed screw is a potential problem) you’re looking at tripling your buy cost minimum.
I have dual Weber 42 DCOE’s on my Cosworth Vega and they are great but can be tricky to dial them in for each application. Make sure you have the resources to set them up properly initially and they most likely will be very reliable. I briefly drove one 4.2 E-type that had them and was not sure they were enough better than my ZS carbs to make me want to switch though. Could be they were not well dialed in though.
The great thing about Webers is that they are infinitely adjustable. The bad thing about Webers is that they are infinitely adjustable. You need a shaman and a bucket full of small parts to make them right.
The manifold can’t fit both the early XK’s and E-Types. All E-Types are straight port and the early XK’s are not.
My 69 OTS came with Webers and I took them off and installed Triple SUs
The Webers sounded great at full throttle but sucked gas and performance was only OK
They were impossible to tune and very expensive to tune as you need 6 of several jets, air correctors and emulsion tubes every time you want to make an adjustment
Performance was much better with the SUs
I recommend to not install webers unless you have a weber expert that will tune them and the budget for the tuning
Hi, I honestly have no idea… I apologize I should have made it clear it’s not my auction on eBay. I just saw it and thought someone on the forum might be interested.
Robert
