Look at this madness. Only one who has been there can appreciate.
These little holes are the stuff of nightmares.
The closer i looked at each, especially exhaust side core plug holes, hypnotically drawn in attempting to clean and analyze i expect Dante to emerge from the 7th circle.
I may very well spam each xk engine car forum to remind everyone. I don’t care what they say. Too important.
This stuff causes 80%+ of xk motor troubles, I am convinced.
I don’t care how good the apparent condition of car/motor, if this has not been done during your ownership or PO hasn’t specifically stated such, expect this. Hope for better, but expect this…
Expect the core passages to be filled with sand, goop, and pure evil…
My car appeared well cared for, sat for a very long time, but miraculously well preserved.
Now damnit i already own another s1 xj6i hoped would be the one, which now has since become a bit of a talisman or parts aid for present one.
All my time at British and Jaguar shows over the years, never once anywhere have I ever seen a S1 XJ6.
The tires it came with barely kept together rolling off deluvery truck.
A great rust free time warp car with tires from company defunct since 70s per research!
My new one has P5 PIRELLI tires …those made specifically for Jaguar…dated 1980 and in perfect condition!
The car is ridiculously original.
Well, i have been away from all of this for years. Always was a jaguar guy, always owned one since my first car.
I know what they sound and feel like, what they need etc etc. No expert, whatever that is, but i always habe done my own work. Would never trust my cars with anyone else…especially as a perfectionist.
Upon arrival on trailer, seller knew nothing. I went on my gut going after sight unseen.(yeah i know)…and i was right. Thankfully.
A bit out of practice, this time i remembered adage, buy the seller, not the item.
Idle set super high, dangerosly so…shut off immediately and rolled it off trailer, let driver go…tuned and adjusted carbs, sounded perfect. No noises, hickups, nothing. Appeared very well preserved. Oil pressure, shifting, etc…charging…all lights working.
Drove around block once and parked it since.
Despite anythimg PO says or any gut feelings, i treat each car as if nothing’s ever been done.
Go through all front to back as matter of course without starting again.
I hoped to simply disassemble engine bay and paint/detail everything for most part.
Removed cam covers, all looked really good.
Apparently head gasket and head removed recently.
Oil leaks from cam covers made block and all a mess.
Zero rust amywhere or ever on this car.
Nevada car since 74, same owner.
Anyway all looked good once again. Coolant, oil dirty but ok. No smells, correct consistency…etc…
So, HERE WE GO…
…although water pump felt perfect. No slack, no noise, perfect movement, etc, i removed as hoses appeared old, and i wished to flush cooling system ad nauseum.
Wow… I could not have been more surprised and shocked. It appeared it was rescued from the Titanic.
I’ve never seen anything like it in all my years or all my cars, from mk2 to mk7, to s3 xj…you name it.
Purchased rebuilt unit from Terry’s.
Not only, but also found pump outlet completely plugged with hard, sand concrete like stuff.
Heart sank a bit.
Knew there was much more to uncover.
I had rebuilt carbs and other parts now wrapped up and awaiting reinstall.
Removed intake manifold.
Revealed a bit of corrosion damage at one port on block along with sandy congealed green goop.
This car’s been sitting a long damn time within that garage…
Tap water WILL MAKE SAND PEOPLE!
I REMEMBER AS KID THINKING DISTILLED H2O WAS EXCESSIVE, NO WAY … Can’t be a real thing.
Yes, chemistry is a thing!!
So, I remove exhaust manifolds, everything has come apart easily which again appeals to belief head recently serviced.
Remove starter as intended to go through it too…while I’m there.
Reveals completely corroded freeze plug(s).
Heater tube running length of block beneath intake manifold completely blocked and rusted internally.
As an important note…
Prior to all this upon initially removing water pump, i flushed and flushed and flushed…
It really wasnt bad. NO signs…Only initiall was there some rust colored water…
Back flushed every with way all afternooon regardless.
The water coming out potable it seemed.
So, nervous and considering whether i can continue with this project, procrastinating, i perform compression test.
Avoiding as it would be do or die time.
Car dead cold, sitting for months and never started since initial drive around back.
Compression was good really dry and upon sitting months, but inconclusive…well, 90 on #2, low on #3 too…
Thought ah shit…
But a bit of oil sent them to 150+.
Noticed blow by at intake for each however…the oil i dropped in for wet test.
Long to short, valve clearances …nothing…i mean nothing.
No clearance at intake tappets.
Newer markings and locking wire revealed it had head removed.
Leak test confirmed intake valves not closing…not burnt at all i believe per images, but maladjustment…who knows now
…a bit from dipstick tube…but a very faint echo really, nothing felt.
In addition, one pristine glop of that congealed sandy goop sitting at one exhaust port.
How the hell?
Only possible thought, crack at exhaust port? But nothing visible.
Nothing unable to be seen could pass that gravel goop through it.
Mystery.
Images taken w phone within ports reveal a lot of carbon on valves.
I must rebuild head … Have no idea what corrosion may exist on block/head.
No signs of head gasket issues however.
But it must be done. Head must be rebuilt.
I can do that. When will i ever have all stripped like this again?
No way i could let it go anyway, it’s begging to be done.
Anyway, again hesitating, i finally remove core plugs…
Welcome to hell…
That’s the exhaust side … The better side.
The intake…
Filled with mud, goop sand whatever…
The car has 44k on it…i believe it is original.
The car is that crazy original.
So, curiosity getting best of me, time to try and clean this out, see what I’m dealing with…
…be afraid…
They actually cleaned up well first attempt…but…
Exhaust
Intake
Now of course there is more to do cleaning addressing corrosion, but it will be blessing of gods if i can manage to remove these without snapping any.
Intake side down to pencil width on a couple.
Intend to take all time in world using corrosion killers, liquid wtench chemicals, acetone/trans fluid mix, torch heat and penetrant cycles, you name it…
But…
Suddenly feel i may have reached my burn out point here already, 2nd car in…
The s1 xj a dream car of mine, having owned most, i find it best of both worlds…perfect saloon, lifetime car…but…
I’m tired.
But i research helicoil and left hand drill bits, etc…may be doable.
Perhaps i need a break.
Anyway, any thoughts appreciated.
AND MAKE POINT TO CLEAN YOUR BLOCK PROPERLY REMOVING CORE PLUGS ASAP.
A NORMAL FLUSH WILL NOT DO IT no matter how long or any magic product.
This is cause of alnost all overheating issues on these motors.
As a final note, the original radiator looks great inside.
I simply hope no crack in block. If so, I’m done.
Can’t do that at this point in my life.
Hope for the best. I feel i may get lucky…but who the hell knows.
OTHER INTENDED LESSON, ONE REALLY CANNOT JUDGE ANYTHING FROM THE EXTERIOR.
Kind regards
TIA for any suggestions.
